caliper hitting bracket with 14bff disc swap (with pics)
It sure seems like that part should be inboard of the bracket when everything is assembled.
it should, i'll have to grind probably about 1/2" off that little nub. grindig the calipers doesn't bother me, i had to grind the front to fit the 15" wheels and i'm sure i'll have to grind some off the rear to fit the wheels
I've ground down that little nub once on a newer mid 80's truck after the owner wanted me to swap in some first design axles in it and the newer calipers would not bolt right on to the older caliper mounts. Simple fix was grind down the nub on the calipers and everything fit like a glove.
that's what i did, fit's great now...
sorryfor nukeing it
