makovai
well i use the little yellow thing under my front tire. I was just thinking of waking up and smelling the mellinium with a little more technology
IGOR said:
.I know of two sets that never could be made to only work well as PARKING brake over any reasonable time span.makovai said:wow! this is weird on the eldy brakes. Last time i was reading posts about them everyone complained that they were hard to adjust and needed rebuilding about once a year.
Manny you got my eyes opened. Maybe i will call BW and see what they cost. I just need the calipers as i have levers, lines, and everything else. I actually have 2 sets of 77 seville calipers here. They are identical to the eldy brakes ecept they have a little long piston in them. Sold one set on ebay last weekend, But i may hang onto the other set until i get this figured out.
that is a pretty cheap way out...
muddybuddy said:the only reason im going to run parking brake is because it will fail safety inspection if i dont![]()
shane74 said:I use dual manual line locks (1 front 1 rear). They are the cheap ones ($35 ea.) but I only use them in off camber situations or in a parking lot (theft deterent if you don't know what it is). There have been a few times when the only tire getting any real grip is on the front.
so what if you wanted to use a line lock with a momentary push button...id like to have rear brake for when im climbing since i run a manual but id also like to have a toggle if i stop and need to get out...id put the btton on the steering wheel just like a trans brake..opinions?
