Ok guys, I got a local buddy struggling with his 6.2 oil burner. He's not on here, but he has hit a point of frustration where he might bail on his project. While he might want to go switch to gasoline he's got too much money stuffed into the project in total to just unload it. Going EFI gas isn't a cheap way to go either as he'd have to change everything from the fuel tank forward, exhaust, wiring, ect.
So here's the gory details. The truck is a 84 GMC Suburban, factory 6.2 diesel/700r4. It started out as a half ton, but it's rolling on 1tons, 37's with 6" lift. He picked up and installed a unused Banks Sidewinder turbo kit for it and installed it with the stock injection pump. As far as I know the engine was a reman/rebuild shortly before he got it but I'm a little fuzzy on that detail. Here's an idea of what we are working with.
He ran the Banks turbo with the stock IP and found it was lacking for power. Doggish. More than a turbo'd 6.2 should be at least. He got his hands on a military J-code IP and swapped in with the bigger/better injectors than the stock civvy 6.2 stuff. I'm told he pulled the 12v stuff off of the original IP and swapped out the 24v parts off of the J-code pump before installing it. That's where the proverbial crap hit the fan I'm told. He fired it up with that combo and it instantly went into a runaway scenario. Couldn't shut the damn thing down. Turbo wound up and all. By some stroke of luck he got it shut off, checked out some stuff and fired it up again. Yep, you guessed it the 6.2 ran away again. After a couple of panic phone calls to another guy he got the idea to pinch the fuel line off and sure enough, it shut it down.
He called the guy he had got the IP from and was told to send it back to him, he'd go through it and send it back. He pulled it, sent it to the guy and got it back. The IP was fixed (don't know what he did) and my buddy installed it. Fired it up and yet again it ran like it had a brick on the throttle.
He's totally frustrated right now and considering dumping the whole truck after putting the stock IP and injectors back on it. He's capable in swapping parts on and off, but he just lacks the ability to diagnose the problem.
I openly admit I know jack squat about the 6.2/6.5 diesels. But I don't want to see my buddy dump the whole truck over the problem as he's going to take a bath on it. I'm open to suggestions, ideas or if there is one of you that is fairly local (Colorado front range) we could get the truck to and he paid somebody to fix it right. I know there are a few of you guys on here that know what you are doing around one of these. @AgDieseler @tRustyK5 @KirsL @imiceman44 @Truckman4life @GWeakland620 @K5wrench You guys came to mind but I know I may have missed some, tag anybody else that have more of a clue than I have.
I appreciate the help that anybody can provide and will pass it straight to him. Thanks guys!
