Yeah that’s pretty much what I built it from .https://therangerstation.com/tech_library/york_compressor.shtml
I’ve never messed with them in an air compressor setup, but I have this article saved. Don’t know if it’ll help or not.
I might just do that I have one laying around I think .I'm sure that there is a small amount of blowby, but what can it hurt? If the crankcase gets pressurized, its just going to leak past the rings in the other direction on the suction stroke.
No idea what kind of pressure could develop even with worn rings. While you are plugging, why not hook a 0-100 psi gauge to one hole and see what you see.
That will give you an idea of how much pressure a sight glass would have to stand.
I do like the idea of a sight glass, since any oil that goes out the pressure side will not return, unlike an AC system. But, some glasses are designed to handle high pressure, such as the old refrigeration sight glasses used to check freon levels, and others are not. Such as the sight glass on a hydraulic storage tank.
If you do hook up a gauge, be sure to post what you find back here in case some others are looking to add a sight glass.
Just plugged the ports and put a gauge in ,it builds up about 45 psi in the case . Gonna try and find a better sight glass too. But plugging the holes worked to stop the leaks lol.I'm sure that there is a small amount of blowby, but what can it hurt? If the crankcase gets pressurized, its just going to leak past the rings in the other direction on the suction stroke.
