hi
can you please guide me to choose a good cam for this application
I am gathering parts for a 454 BBC budget build for my k15
the truck is 1986 GMC K15
14BFF + 10bolts >> 3.73 gears
SM465 + NP205
33" tires
total weight with 350 SBC is almost 5000 lbs ( more with the BBC )
454 truck motor from a mid 80s Burb ( + 0.030 overbore )
236 peanut port heads + oversized valves 2.19/1.88 + DIY porting
stock crank + stock rods ( with ARP bolts )
TRW L2399F30 pistons ( CR almost 9:1 )
Performer RPM intake ( square + spread pattern )
Performer 1407 750 cfm carb ( with offroad needle kit ) OR a Q-Jet carb
HEI dizzy with MSD module and coil ( MSD6AL is also available )
long tube headers + dual 2.5 exhaust + Throush glasspack mufflers
the truck is used in sand dunes + street + sometimes in the mud
and I want to retain the AC/PS/power brakes and be able to use cheap low octane fuel
also I don't want to spend a lot on the valve train since I am not going to wind it past 5500 RPM
which one do you think is more suitable for this application ?
http://store.summitracing.com/partdetail.asp?part=CCA-11-242-3
Comp Cams XE268h
Duration at 050 inch Lift: 224 int./230 exh.
Advertised Duration: 268 int./280 exh.
Valve Lift with Factory Rocker Arm Ratio: 0.515 int./0.520 exh. lift
Lobe Separation (degrees): 110
http://store.summitracing.com/partdetail.asp?part=CCA-11-246-3
Comp Cams XE274h
Duration at 050 inch Lift: 230 int./236 exh.
Advertised Duration: 274 int./286 exh.
Valve Lift with Factory Rocker Arm Ratio: 0.552 int./0.555 exh. lift
http://store.summitracing.com/partdetail.asp?part=CCA-11-239-3
Comp Cams X4 270H
Duration at 050 inch Lift: 226 int./234 exh.
Advertised Duration: 270 int./278 exh.
Valve Lift with Factory Rocker Arm Ratio: 0.544 int./0.564 exh. lift >> too much lift ?
Lobe Separation (degrees): 111
http://store.summitracing.com/partdetail.asp?part=CCA-11-207-3
Comp Cams Magnum 270H
Duration at 050 inch Lift: 224 int./224 exh.
Advertised Duration: 270 int./270 exh.
Valve Lift with Factory Rocker Arm Ratio: 0.510 int./0.510 exh. lift
http://store.summitracing.com/partdetail.asp?part=CRN%2D10306&view=1&N=700+
Crane Cams 10306
Duration at 050 inch Lift: 228 int./228 exh.
Advertised Duration: 284 int./284 exh.
Valve Lift with Factory Rocker Arm Ratio: 0.544 int./0.544 exh. lift
Lobe Separation (degrees): 112
http://store.summitracing.com/partdetail.asp?part=CRN-10307
Crane Cams 10307
Duration at 050 inch Lift: 226 int./226 exh.
Advertised Duration: 282 int./282 exh.
Valve Lift with Factory Rocker Arm Ratio: 0.533 int./0.533 exh. lift
Lobe Separation (degrees): 108
http://store.summitracing.com/partdetail.asp?part=CRN-10305
Crane Cams 10305
Duration at 050 inch Lift: 216 int./216 exh.
Advertised Duration: 272 int./272 exh.
Valve Lift with Factory Rocker Arm Ratio: 0.515 int./0.515 exh. lift
http://store.summitracing.com/partdetail.asp?part=sum-1302
Summit Racing 1302
Duration at 050 inch Lift: 228 int./238 exh.
Advertised Duration: 286 int./296 exh.
Valve Lift with Factory Rocker Arm Ratio: 0.540 int./0.540 exh. lift
Lobe Separation (degrees): 114
http://store.summitracing.com/partdetail.asp?part=LUN-60203&autoview=sku
Lunati VooDoo 268
Duration at 050 inch Lift: 227 int./233 exh.
Advertised Duration: 268 int./276 exh.
Valve Lift with Factory Rocker Arm Ratio: 0.542 int./0.554 exh. lift
http://store.summitracing.com/partdetail.asp?part=LUN-60202&autoview=sku
Lunati VooDoo 262
Duration at 050 inch Lift: 219 int./227 exh.
Advertised Duration: 262 int./268 exh.
Valve Lift with Factory Rocker Arm Ratio: 0.530 int./0.542 exh. lift
sorry for the long list
your suggestions is highly appreciated
thanks
Ahmed
SM465 + NP205
33" tires
Comp Cams XE268h
Comp Cams XE274h
Comp Cams X4 270H
Crane Cams 10306
Crane Cams 10307
Crane Cams 10305
Summit Racing 1302
Lunati VooDoo 268
Lunati VooDoo 262
thanks
Ahmed
