Cam selection for 400
orangeGMC
Connecticut
Does anybody have any recommendations on what cam I should run in my 400? I have found recommendations for 350s but is there anything different for the 400? I have also read about "small base circle", do I need to look for that? The truck never sees highway, just a little around town and trail. Spends alot of time in the mud. Are any manufacturers better than others?
400 make good tourqe so get a good tourqe cam. and thay dont spin as fast as smaller motors so get one in the rmp range you will be most of the time:wink1: i like comp xtreme 4x4 cams
I found 2 comp xtreme 4x4 cams. Which would be better for low end torque?
The red one or the blue one?
Description
Cam and Lifters, Hydraulic Flat Tappet, Advertised Duration 254/ 262, Lift .447/ .462, Chevy, Small Block, Kit
Cam and Lifters, Hydraulic Flat Tappet, Advertised Duration 250/ 258, Lift .432/ .453, Chevy, Small Block, Kit
Advertised Duration
254 int./262 exh.
250 int./258 exh.
Advertised Exhaust Duration
262
258
Advertised Intake Duration
254
250
Assembly Lubricant Included
Yes
Yes
Basic Operating RPM Range
1,000-5,200 RPM
600-4,600 RPM
where do you run most of the time in power range? and what rpm do you lanch at most of the time? this will help you make a good choice:wink1:
In my truck right now I have a 305, so I have to stay up higher in the RPMs to turn the tires. The 400 is still on the engine stand so I don't know the RPMs it will be running.
I went with the 262 grind, going with 4.56 gears and ported the crap outta the heads....
What is the rest of the combination?
Maybe mine will be in and running this weekend so I can give you the results.
A friend of mine runs the 254 grind in his 388, and it is wicked strong til about 4500 rpm's. Sounds great, lots of throttle response amd torque....
