My slide in has been treated like the trailer trash it is.
while long term plans were to renovate it inside and out, for now I need to fix the sagging upper bunk. I suspect rot has invaded due to multiple fine caulking jobs around the front windows.
Anybody familiar with the construction and where to begin tearing into it, without it becoming a snowball project? Just need to get it usable again for now.
then some flex seal tape and a few brad nails and you'll be gold!!
. I took it apart and replaced all the bad wood and had to figure out some fabrication for the strange corner angles (like you have at the front). There should be screws that hold it all together, probably hidden by the aluminum corner channel, but it's possible that's only stapled. It's a ton of time, but nothing super technical about it. If you do a good job with it, it will be better than factory.
