84CUCV
3/4 ton status
some kid i meet. said his built 6.2 with a sm465. went right up something that was just about vertical. at idle. dont see how that could?? could it?
thanks just wondering
84CUCV said:some kid i meet. said his built 6.2 with a sm465. went right up something that was just about vertical. at idle. dont see how that could?? could it?
6.2Blazer said:The hill might of been steep, but guarantee is was nowhere near vertical. Vertical is 90 degrees, and even with a very grippy surface most vehicles don't have the traction to crawl a much steeper grade than maybe 45-50 degrees.
imiceman44 said:Actually if he's talking about just the front tire, i have seen plenty do that, the rear would still be going on flat and helping with raction against the vertical section.
I have seen rigs climb on a pole.
Granted it's only a few feet up the pole but it still is vertical.![]()
imiceman44 said:hey if we want to be technical, 50 dgerees is actually not feasable unless the tires are made of glue, 45 is the most you can get traction enough to move uphill![]()
