Can anyone identify the tabs an Poly bushings?
SpeedlabDan
Keepin it trashy never classy
Woodstown, New Jersey
They're from the ORD magnum kit and they are pictured on their site for the other kits with the round trans adapter but I can't figure out if I use it with the figure 8 magnum adapter. Just not sure if they're extra or I'm not seeing something? Thanks guys
From what I can tell they go with the round adapter mount that isn't eccentric. But that makes me wonder what may go with the bracket I have
You should have a really thick bracket, that has a partial circle cut out of it. That bolts to Magnum. Then you can weld the brackets in your picture to that piece however you'd like. I ended doing my own brackets and bushings.
Using the stuff in your picture, I envisioned the tabs being welded to the thick piece on the Magnum. The single piece with 2 holes would be welded to a crossmember. Or vice versa.
Chris got back to me at ORD, says it for use with the Ford style Tcase. The bracket that came with my figure 8 has a flat on the bottom about 6 in the it angles upward at maybe 110 deg for another 6". I'll post another pic of the bracket itself when I get home
