urbex
I'm building a 489 for the K5. It started out that it was just supposed to be a dirt cheap budget clean and reseal of a stock 454, then my clumsiness resulted in a damaged piston, and a decision to go bigger with the 489 setup.
Before the piston damage occured, I had painted the block, got new core plugs installed, new cam bearings installed, and cam installed. Now that I'm putting in new pistons and rings, I need to hone the cylinders. For obvious reasons, I don't any bearings installed to soak up honing grit and to make after cleanup easier.
Problem is that I've never had this situation before...can I pull the cam bearings, clean the block, and reinstall them, or are they basically one time install, and I'll need to install another set of bearings?
