I can get a good 2wd th400 for $175...Can I do anything with it? Is there a way to mount a t-case on the back? If its fairly simple/inexpensive to convert it, I'll go pick it up. Or should I wait for a 4wd one?
) After that its just some time to swap the shafts, maybe 5~6 hours depending on your skills and tools. Hope this helps.
Depends. I had a 9.25" 2wd shaft that was previously used with an NP208. I dropped it in and went to bolt up my NP241 using a TH400 to NP241 "short" (heightwise) adapter, and the shaft was an inch or so too long.b454rat said:If you have the bolt on yoke style ouput, and it's 9 1/4" long, then you don't need to swap outputs. Only difference is the length of the splines and a hole at the end....
