Technically using just the body and frame. Sure can, motor mounts are the same, trans mounts will probably be different. You'll need shafts and all the springs and brackets for the SAS in the front, but is certainly doable.
BTW welcome to the boards. You will not find anymore knowledge about GM trucks than you will on here. To have full access a membership is $25, and it more than pays for itself, ask anyone!
