YES!
just a bit of cutting...
i had cut the bottom of the body off aout 6" up from the bottom and installed that 2x4, with some help from an AZ ck5er... now i gotta cut some more, but probably not to this body - the measurements listed below are what i will be doing to the '73 when i get to that point this week.
that's flexing out on a 2' step - i need some bump stops i think - because i've still got more droop in that suspension - but not a whole lot more compression. i figure i'll cut out the wheel wells and find a bigger place to check my flex and go from there.
with 38's installed, my original 35's sitting infront of rear tire to show tire size difference:
my 35's, my neighbors 37's and my 38's:
my cat digging the new high ride....
