Can I get 3.42 gears for D60, or 3.55 for 14-bolt?
rich
central NC
<<<I tried searching on this, but can't get the search to work for terms like 3.42 (even 4.56!). Is there a trick to doing that?>>>
For how I use my truck, I need to re-gear my D60/14-bolt combo to a numerically lower gear ratio than 4.10. But searching for gearsets, I can only find 3.42 and 3.73 for the 14-bolt, and only 3.54 and 3.73 for the D60.
Is it right that I can't match them at anything numerically lower than 3.73?
Has anyone ever seen a 3.42 D60, or 3.55 14-bolt? Know where I can find those gears?
If I can't get numerically lower than 3.73, then it's not worth the money to me to re-gear.
Thanks!
Richard
Note: I've looked at other options like an add-on OD unit, or switching rear axle to D70, so I'm *not* looking for input on that. I also can't use a D44 front - the truck has a Cummins in it, so needs the D60 weight capacity. I'm just interested in whether it's possible to match the D60/14-bolt at anything numerically lower than 3.73. If I can't, I'll go to other options from there. (Not trying to be rude, just wanting to keep the thread on topic.)
3.73 is the lowest you can go for both and match. Could swap out the 14ff for a Dana 70 and run 3.55s.
Thanks for the confirmation.
I have considered going with the D70 and 3.55s, but wanted to stick with the 14-bolt since it's already in the truck and has a Gov-Lock (which is perfect for the street/tow/beach-camp driving I do).
I think I'll stick with what I've got rather than go through the swap, unless I can affordably find a D70 with limited-slip (and hopefully already 3.55). There wasn't a GM D70 in 73-87 GM SRW width, right? My friend has a SRW D70 in a first-gen Dodge Cummins, so I'll measure his to see if it would be an easy swap, maybe just spring perch relocation. But I really don't feel like messing with that, too many other projects. :rolleyes:
A dana 70 with 3.55's should be a realitivly easy find, they are a common rear in alot of 94-01 cummins trucks and after 01 and a 1/2 they are factory disc brake as well.
