On all my old GM's I'd lock the hubs in durning the first snow,and usually just left them locked all winter--but my '82 K2500 has a NP-208 that must have an issue internally,as it still sends power to the front shaft even when its shifted to "2WD" --so that makes for jerky turns and binding on dry pavement,and could prove damaging..it makes it a pain to use when it has snowed,because unless your in 4WD with the plow on it,the rear wheels spin far too easy even on dry tar,to be able to pull out into traffic safely...but a 1/4 mile from that icy intersection,the state road becomes bone dry,and I'm sure thats hard on the transfer case ,tires,etc...but I'm not about to do anything to fix it now either,its too cold and I have a spare T-case to pop in it if this one craps out...it works perfect in 4WD,so I just unlock the hubs if I know the roads will be dry where I'm headed,and cringe every time I come to a snow covered intersection...
I doubt not locking the hubs in every so often would allow rust to form on a ring gear,etc..even in frigid weather I'd think the gear oil would flow when you go around corners,slosh around when you hit bumps,etc---and on every truck I've owned,I can see the front drivehaft spin for several minutes even with the hubs NOT locked in,the grease in the hubs is thick enough to turn the axles until it warms up some anyway..
