Can i mount a 10 bolts yoke on a 12 bolts axle?
COKE
Registered Member
Vitoria(Spain)
Good day,
I,m going to change my rear 10 bolts axle for a 12 bolts.
My truck´s drive- shaft u-joints have a bigger diameter and don,t fit on the 12 bolts yoke.
Can i mount the yoke from my 10 bolts on my 12 bolts axle?
Thanks in advance
Try the search. I know this has been covered before. IIRC, it fits, but requires a different seal. A search should turn up that part number.
I did a search before to ask but i didn,t find nothing interisting.
Searching for the seal you mentioned i have found the answer.
Thanks a lot.
