01maroonz71
well, in the rear, something fishy is goin on. it's so high on the pass. side that it's kickin the drivers front down. so we looked at the springs and on the pass. rear there is about an inch more gap between the overload and the next spring up than there is on the drivers rear. can i remove a spring out of that side to fix this???? im installing shims this week to fix my wobble and wanna do it when it's all apart. would i be better adding an AAL to the other side???? it's pretty bad. BTW, these springs have 10leafs in them and are out of a 1ton pickup truck. they're 56in long and the rear shackle hanger has been drilled back 4inches to accomidate this. the previous owner installed these springs/drilled new holes for the shackle hanger. if not, where can i buy new 56in springs??? I have a shackle flip(4.5in) and 1in raised spring perches, and i need 7-8inches total of lift....
thanks guys
~Dave
thanks guys
~Dave
. It's only a little so I dont really care. But I wouldnt remove a leaf in your case. But now that I think of it my buddys k5 has a different number of leafs in the front on either side for his lift springs, and I'm pretty sure he didnt change them around
