So I've got a passenger side flange that's bent on the '68. The disc wobbles really bad, so I pulled it off and I can see the flange wobble slightly.
Makes sense that I needed shims to correct an out-of-alignment rear caliper on that side. Looks like the axle's PO smacked the curb and bent the axle mounting flange and axle shaft flange.
I this something that can be turned back to straight or am I in for a new F*%#@&^ axle shaft?
