Can I use a 3/4 ton 10 bolt housing/gears with my old 1/2 ton 10bolt?
Nrose07
Salem ,Or
I'm going to get a 10 bolt 3/4 ton front end but its missing axle shafts, tie rod and hubs. I really want it for the gears, but when I did a search on it I found conflicting info. Can I use my old axle shafts and hubs on the 3/4??? The spindles are the same right??? And the tie rod??? Thanks Guys!
Everything should be the same, on both axles if they are both 10 bolts, except the bearing hubs, rotors, and backing plates. So everything should interchange bewteen the 2 axles. The only time that 10 bolts differed is when they changes to 30 spline inner shafts. If the axle you are going to use the gears out of is the 30 spline, and the axles you have are 28 spline, then obviously won't work. Or it could be the other way around. I think they changed the spline count in 89. Pre-89 are 28 spline, and post-89 is 30sp.
Also the 30 spline axles are a little stronger shafts, but harder to find. The 28 spline axles are easier to find but a little weaker.
Guys? This is a front end. I'm pretty sure the spline count stayed the same in those. The only difference I know of is stuff on the outside of the knuckles...I guess rotors and such...basically the stuff that makes it 8 lug. So you can mix and match the gears, housings and shafts.
Look at the 89-91 year model in the spec. link. Says 30 spline. http://coloradok5.com/specs.shtml .I have also heard that the 30 spline carrier is weaker then the 28 spline carrier too. But most of the time the axle joint is usually the first thing to let go in the front end. So I don't think it really matters unless you decide to run the chrome moly shafts and joints. For that matter we don't even know what year trucks the axles are out of.
