handloader90
Building!
Cast iron Q-Jet intake.
Was gonna use the vac port on the back of the intake in front of the dizzy but my th350 vac line is hooked in there along with some vac lines for the A/C all on the same fitting.
My Holley only has one 3/8 vac line. No provisions for me to put in another fitting that I've found.
My brake vac line was connected to the vac port on the carb... never had one setup like that before. I've always ran my brake vac line from a fitting on the manifold.
I've always connected my PCV valve line to the fitting on the carb.
Can I use this big port on the drivers side of the intake just under the carb?
