nocturnalnasty
Registered Member
Can someone tell me if it is possible that I have done my math wrong or maybe I'm doing something else wrong?
I have a 1990 suburban with a 700R4/208 and 38" TSL/SX's with a D60 front and 14BFF rear that I just put under the truck.
The PO of the axles told me that the axles had 4.10 gears. I have not had the inspection plate off the 14 bolt rear end, but my buddy who is a really good mechanic has and he confirmed that the ring is stamped with the correct numbers for a 4.10 gear set.
Now from what I can tell my 700R4 should have
1st gear 3.06-1 ratio
2nd gear 1.63-1 ratio
3rd gear 1.00-1 ratio
4th OD .70-1 ratio
So here is my math. Based on a 1.00-1 final transmission (3rd Gear) at 65 MPH.
RPM = MPH x Gear Ratio x 336 / Tire Diameter in inches
RPM = 65 x 4.10 x 336 = 89,544 / 38" TSL
RPM = 2,356
But my RPM is 2,800 at a GPS'ed 65 miles per hour on flat highway. Which would mean my gear ratio would be closer to 4.88 to 1.
So does anyone have any idea where I am going wrong?
John
4th OD .70-1 ratio
RPM = 2,356
John
