Can this be welded?
PsRumors
Cartersville, GA
Installed a 14 bolt FF. The axle that came out had a steel spring perch. The axle that went in has almost a cast perch. It is welded to the tube but was wondering if it could be welded upon.
Need to weld a couple brackets to it to hold the disc brake hose.
