"Cant find a Leak Down Tester!!!
chaka73
Southern California
\"Cant find a Leak Down Tester!!!
Hey guys me again with the same problem, smoke coming out of my tailpipe from what I can see it looks black, but I noticed what might be an important hint so you guys might be able to help me, that it only smokes when its in idle but if I accelerate a little bit the smoke is gone nothing comes out the tail pipe, but once I let the gas go and it's back on idle it's back to smoking again and like I said it looks more black than anything so do you guys think it could be my carburetor, cause if it was the valves or something else wrong with the engine I think that the smoke wouln't stop when I accelerate right? what do you guys think? and as far as the leak down tester I asked around here and nobody seems to know what the heck I'm talking about went to Autozone, local parts store, Pep Boys and no luck so what do I do guys thanks.
keep blazin !!!
Re: \"Cant find a Leak Down Tester!!!
You can make your own if you get a fiting that threads into the spark plug hole
then you need a short piece of hose and a pressure regulator
all you are tring to do is apply pressure to the cylinder and find out where the majority of the leakage is comming from. (intake,exhaust or rings) then you can track down the problem from there
David
Drive It Like You Stole It !!!!
if its BLACK smoke its unburnt fuel, I would suspect the Carb, check the choke and see if its sticking..WK
