So I have a small coolant leak that I can't seem to pin point. I can trace where its drips from, but able to find the source of the leak. (Or I'm in denial of where it's coming from). I can follow the water drool back to the motor mount, but loose it from there. I also get drops on the drag link. I feel around the water pump neck, radiator hose, and other hoses, but they are all dry. Can a freeze plug have a slow leak?? I've seen corroded freeze plugs, but they leaked like a sieve. The other plugs I see are okay. This leak has been present for a while, but the tahoe is rarely driven.
I wipe of the drops and coolant line, lay under the truck while its running and I see nothing leaking. I only find drops of coolant after diving. Guessing that's pressure related?
It's a 5.7 99 tahoe.
