wakeup
Registered Member
I have an 84 k10 with a th350 and a 3 inch body lift. The shifter is adjusted so that it works properly when the truck is level. Other stuff too, but those are the relevant bits.
My problem is that when off road when I get the truck twisted up it will pull my shifter either up a gear or two or down, depending on which way the truck is flexing. Some times bringing it from drive to reverse or the other way around, and commonly putting it in neutral.
I'm looking for any advice to held reduce or eliminate this problem. Thanks guys.
(and that was with new motor and trans mounts) i bent the linkage up some and all is well now. But that cable sounds way easier and less headaches.
