Did you take off the snap ring on the body? You have written "the snap ring" which I’ve assume you mean singular. There are two snap rings that hold each hub on. One small one for the axle shaft and a big one for the hub body.
thanks anyway guys i figured it out i already took both hubs apart and put em back together. I couldnt see the large snap ring that went around the outside of the hub body.
