Can you tell me what you did exactly.
1) You said bad connection - did you replace the switch or clean the electronics? what did you do and how did you get to everything?
2) You ran a bigger wire. From where to what point on the truck?
I had to do the bypass switch thingy to get the window up while the tailgate was done, do you have to take the whole regulator out to get the switch out? That is a real mutha frocker to get those two lil nuts off. I was working on it but gave up and wanted to check here before progressing any further.
I had noticed that I needed to turn the key hard to the left to get the window to go up, like it was barely making contact, is there things that can wear out? If so, what would get replaced, the whole cylnder lock for an electric tailgate?
