p47flyboy
Registered Member
Just bought ex-military k5 blazer. At this time I have to raise hood and attach a wire to a terminal on a relay to activate the glow plugs. The seller said turn key on and wait 30 seconds then remove wire then crank. It finally worked on the 3rd try but I left the wire connected. This worked fine for several days but now I can't get it started. I've put about 20 miles on it after topping off the fuel tank. Do you pump the accelerator while starting a diesel? Any info that might help will be appreciated and thanks.
