I have a quadrajet on a mid '80s 454 with a mechanical external fuel pump. I cranked it up like normal and it ran for a couple of minutes and then died suddenly. I tried to restart it and it would start but then immediately die again. I checked if the carb was getting fuel and when I would manually pump the accelerator under the hood, it would spray like normal. Even though I can pump the pedal a few times and it would start up, it will not keep running. I tried pouring fuel directly into the carb and again it would crank but wouldn't keep running. I've tried pumping the accelerator right after it cranks but it will not keep running. If fuel will squirt from the jets, why will it not keep running? I assumed if the carb will squirt fuel from the jets then the fuel pump must be working. Could the fuel pump still be causing this or is it the carb?
Thanks
Thanks
