Carb / ignition question
ellero
Covington, Georgia
I have been told that teh computer controlled Q-jet sucks and I need to get a non computer controlled Q-jet. I did that. Before I change out the carb, what other things do I need to get to make the truck run right not that I will be getting rid of the computer stuff and where is the best place to get them?
If you're just swapping carbs, they should change right over. I would rebuild the Q-jet before putting it on your truck and be prepared to tune it once its on there. Replace the fuel filter too.
A friend of mine (a boat mechanic) said I might need to change out the distributor and ignition system too since there will be a lot of electronics disconnected when the carb is removed. Yes it is being rebuilt first. Is this true or will the stock electrical set up work right.
You'll need another distributor.
No, the CCC Q-jets don't suck, they are essentialy the same as any other Q-jet, except primary fuel metering is handled by a solenoid, and they have a TPS. The setup is as close to TBI as you can get without injectors. Has an O2 sensor and all. The CCC carbs suffer from the same problems any other Q-jet does, mainly wear and junk in the float bowl, carbon buildup, and the only real other problem that is exclusive to the CCC carb, the TPS.
If something is wrong in the system (like bad MAP sensor, etc) then of course it won't run right, and changing the cam or engine can cause problems, but that is no different than the fuel injection systems.
