Well, the problem with throwing parts at a problem is not so much the cost, as the fact you might not fix it.
But, if you can find one on Sunday, and its reasonably priced, I would consider an ignition module at this point.
Even though they are common to fail, and are fairly cheap, I would not normally advise just trying one without trying to verify no spark, but you say you need this running today.
Fuel problems are not totally ruled out, but I am leaning towards spark. And the most likely thing to kill it after running for a while is the module.
If you do a spark check, it should be nice and blue. Small and yellow is a problem. I would take a plug wire off first and put it back on to loosen it up.
Then have a screwdriver or a spare plug ready.
Run it until it quits, then put the screwdriver into the end of the plug wire and put the shank next to a ground, or put on the spare plug.
Crank it and watch the spark.
With any luck, you will not have one. In this case bad is good. If you have no spark, it shows you where to start looking.
A failing module could cause a weak spark, which would cause the hard starting problem, and then it could quit completely causing it to die.
