elyon
Here's the set up:
383 stroker
Edelbrock 122 e-force roots style supercharger
Quick fuel Q750 boost referenced carb
Edelbrock performer 110 GPH/5 psi mechanical fuel pump
Aero motive fuel pressure regulator set to 5 psi
Poweredex AFR fuel air monitor
The oddity. On a hot day, say upper 80's to mid 90's. High humidity.
After sitting in traffic for a light or something, accelerate, let up in the throttle and AFR will go from around 12:1 to 8:1. It will flood itself out. If I see it happen I can give it a little extra throttle and it will correct itself in a few seconds. It can happen when light throttle cruising and then closing the throttle. I can sometimes smell fuel.
All engine perameters are normal.
This only happens when pretty hot out and high humidity. Any other time, no problem.
Fuel levels are half way up the sight glass on the float bowl as specified. Fuel pressure is below specified 6.5-7.0. Pump only makes 5.
Some kind of super cooling on back side of throttle plates?
I'm at a loss.
383 stroker
I'm at a loss.
