blowedupmotor87
My K3o has a 383 stroker with what appears to be a GM performance high-rise Quadrajet style intake. The day I bought it, it had a Holley 750 double pumper with a manual choke and mechanical secondaries. That carb was leaking like a sieve, the previous owner said he would get it rebuilt for me for free since he had said it was a running truck. (six months ago... I doubt I will ever see the carb again, he wont return calls or texts) I highly doubt the 750 double pumper would have been a good offroad carb anyway but, would be nice to have it now to get the truck running and then sell the carb later!!!!
So.... that leaves me with no carb and a lawn ornament for a truck! I need a carb pronto as my HOA has given me until february 1st to register my truck or remove it from my driveway before they fine me.
What would y'all recommend??? I am guessing it needs to be 750CFM since it (supposedly) ran great with the Holley double pumper. It is purported to be a 383 stroker from an asphalt late model race car so I would assume it has fairly high compression (compression test was 220psi on 6/8 of the cylinders, one was low (110psi), one was very low (50psi) so, the motor will need to be pulled and rebuilt but, I need to get it running long enough to inspect and register so it can continue to sit in the driveway), it also likely has a fairly aggressive cam.
I'd like to go EFI but, that is not in the budget nor do I suspect I would be able to work the kinks out of an EFI swap in such short time. So, the focus now is on what carb to run!
I am thinking about this one, the question I have though is- why does it say up to '85? Is '86 different somehow??? Also, does it even matter since the motor isn't original to the truck anyway???
http://www.summitracing.com/parts/sum-210214/overview/
Any thoughts and advice would be greatly appreciated, I know basically zero about carbs!
