Carbuerated Propane Setup (TX)
fallout232
Dallas Texas
I have a semi-complete Carbuerated Propane Setup I pulled off a Running 1971 Chevy Truck. The condition is "Rough" It Includes the Tank, The Regulator, and the Diffuser for the Carbuerator. This has been sitting outside for about a year now, The tank needs sanding and repainting. The bottom of the tank is rusty however a sanding disc should clean it up. I dont know if the pressure regulator will need any parts replaced, (Again it was running when I pulled it.) It will need new copper lines ran from the tank to the regulator and a hot wire run from the ignition to the solenoid on the regulator. I dont know if the gauges on the tank are working or accurate I didnt pay that much attention to it when I pulled it off. I cant ship this, The tank is massive and weights 150 lbs easy by itself. Id like to get 275.00 for it but make me an offer if you dont think thats fair. 20 minutes south of Dallas on IH35E.
