buffblazer
would a 750cfm edlebrock carb be to much for a 350 bored .40 with stock heads? will a 600cfm be to small? seems like there is a big jump there im wanting the most performace i can get.
You can put a 750cfm on a SBC and it will run ok. But you will loose low end torque and take a big hit in gas MPG.
Unless its a Q-jet![]()
! Very true!
Beings the post was about edelbrock I was refering to square bore carbs.
But
Edelbrock Thunder AVS series carbs are very similar to Q-jets. They are a spread bore. The 650 CFM would be great on SBC.
Edelbrock Thunder AVS carbs are a copy of the old Carter AVS carbs. They are a spread bore with an air valve like Q-jets and Thermoquads. But not made out of plastic like the old Thermoquads. Chevy used them for a few years in the mid 60s and dodge used them up untill the early 70s
The Edelbrock AVS carbs are built by Webber.
Instead I bought a slightly used Edelbrock Q-Jet.AVS are a spread bore carb. I garrentee you that. They list them as square bore because they fit square bore manifolds. On AVS carbs the primary bores are smaller than the secondary. Like on Q-jets. It is a classic spread bore design. But dont believe my words. I will let some pics do the talking for me.
The carb on the left is the Thunder AVS. The carb on the right in a regular Performer carb. You can easily see the diference between the 2 carbs.
The AVS on left has smaller primaries than the secondaries = SPREADBORE.
The performer on the right venturies are all the same size= SQUAREBORE.
BTW Edelbrock still sells their new Q-Jets too. At least untill their stock on hand is gone.
http://store.edelbrock.com/edelbrockcarbsq-jetapplicationcarbs.aspx
Dont really have much experience with them. I had a Carter AVS on my old 67 Camaro RS.
Chevy only used them for a few years 66-67 and only on some models of 327s. It was a PIA to get parts for so I swapped it out for a Q-Jet. Camaro Ran better with the Q-Jet once I got it tuned good.
Must be the reason Q-Jets were used by GM for 20 some odd years.
Indeed... and also the reason I sold my AFB and got the Edelbrock Q-Jet...
would the 600cfm performer carb be just fine, or would i be more happy with the 650 off road carb
