Carpet adhesive
TJ1978
I have MANY questions
East Valley, Arizona
I just picked up this used rug from a C10 to cut-up and use in my K5... which I did. Bottom is a bit crusty but for my purposes, which was to cover the killomat it’s just fine.
Anywho....
Any recommendations on an adhesive that will stick to the killamat sound deadner? Will a double stick tape work?
I used a few zip ties through the rug around the driver and passenger side to keep it from sliding forward. But I’d lik a way to keep it more flush to the floor. Especially around the gas pedal and over the transmission bump.
Is there a less than permanent adhesive I’d like to be able to pull and clean if needed.
https://www.homedepot.com/p/Roberts...struction-Repairs-and-Crafts-007-17/311276007
Or
https://www.autozone.com/sealants-g...VMBitBh0AsQe1EAQYAiABEgJ-YvD_BwE&gclsrc=aw.ds
I ordered a double stick tape from amazon. I don’t want it to be permanent... yes, Velcro would probably be a good option if this tape doesn’t work out..
