otterby
Newbie
I have an '89 K5. I recently installed new ball joints and tie rod ends. When I got it aligned the shop told me it would cost about and extra $150 to adjust the camber and caster and they'd have to order the correct bushings. They gave me a printout that I've attached and told me it was easy just to follow the instructions. My problem is the the printout picture doesnt match the bushing that I purchased and the instructions are no help. I assumed that the slot in the bushing woluld be in the thin part where the blue line is refrencing. The slot however is the area of about middle thickness. Do I put the thin part of the bushing at 214 degrees (blue line) like the picture shows or do I put the slot at 214 degrees? Also, I assume that 0 degrees is pointed toward the diff?
