sled_dog
1 ton status
to be noticeable, I greatly agree it would have to be a big time load, but you also won't really notice a degree or two. Except maybe a slight pull if the load were to one side for some reason.
73k5blazer said:According the my 1973 GM Service Manual, and my brother, who's a tire wheel engineer for GM who looked up the spec for a '91, the K10 & K20 Alignment specs which matched the ones in my 73 GM service manual, so 1973-1991 K10 & K20 are as follows:
Caster: +4* Not resettable (well it is sligtly if you use different length schackles)
Camber: +1.5* Not resettable (well it is with the upper ball joint special sleeve or the camber shim between the spindle & knuckle)
Toe: 3/16" (exc K10 w/ Full time 4wd= 0")
Tolerances are as follows:
Service Check:
Caster: +/- 1*
Camber: +/- 3/4*
Toe: +/- 1/8"
Camber (Sdde-to-side): 1*
Caster(Side-to-side): 1*
Service Reset:
Caster: +/- 1/2*
Camber: +/- 1/2*
Toe: +/- 1/16"
Camber(side-to-side): 1/2*
Caster(side to side): 1/2*
(Service check states: Values within these limits should provice a high level of customer satisfaction and shoud not require resetting
Service reset states: Values that the vehicle should be set within if it observed out of the service checking tolerace or if it is being aligned due to replacment components or for any other reasons)
besides hopefully camber
