7387chevynut
Registered Member
Hi guys,
I had new dual exhaust put on my 90 blazer, and forgot about the O2 sensor, and now found out that without the O2 sensor that the motor will run ****ty once its warmed over and stall on me in gear.
Somebody told me that even if I install the o2 sensor on the exhuast.........that I will still need a Cat converter for the whole system to run correctly.
But if so, then how does that work with DUAL exhaust? will I need 2 converters or just one installed on O2 sensor side pipe.
Just curious if anybody else runs 87-91 K5s with out Cat Converters (and I'm sure theres a few) and what you guys do.
