readymix
3/4 ton status
I will check the distro today. Thanks for the ideas. Keep 'em coming
Well both manifolds were red hot so it would have to be more than 1 valve not sealing right.
I can't drive it yet, the passenger side manifold is broken in half. It has been leaking for a while and I guess this finished it off. Time to find that header review thread again![]()
The timing was spot on.
So now the question is....will a clogged cat cause the exhaust to run as hot as it did, or do I have another issue?
