[ QUOTE ]
First of all, define "bomb" for me. The following modifications would be "bombed" enough for me, maybe not up to your standards. 3116 would need a custom ground cam, marine injectors that might need a little work to open up the orifices on the tip, some sort of twin turbo setup (not sure what turbos to use), marine pistons for the low compression, and some governor work to make it turn 3500+ rpm. The HEUI engines could probably get by with stock marine injectors, marine pistons, cam would probably be fine since it only actuates the valves on this engine. Again, some sort of twin turbo setup, and of course custom software. I am not familiar with the Edge boxes for Cat engines, so that may be sufficient, maybe not.
[/ QUOTE ]
By "bombed" I meant an engine designed for hi performance pulling and drags. Not a tow rig or daily driver, what we had a conversation about in this forum not to long ago...about the electronic vs. mech ISB's. Building a Cat that could compete with the 700/1600 numbers people seem to be making with the 12v ISB's. /forums/images/graemlins/thumb.gif
[ QUOTE ]
[/ QUOTE ] That is the headache that I see is associated with building a seriously "bombed" cat. I wouldn't know who to go to to get custom software programmed and Edge does not make anything for a Cat from what I have seen probably because there is no demand for it.
