what causes the crack around the door striker bolt?
Those "inner rocker panels" are what gives the rocker and cab most of their support,and prevent flexing ,besides the cab mounts and rubber mounts,so yeah,I'd say that could be contributing to your problem..............................................................................................I recently decided to patch a few minor looking holes in my '82 GMC's rockers that were bubbly on the surface under the door...--I could hear the drivers door rattling when I hit bumps,and the hinges and bushings are tight--so I figured it must have rot somewhere--I was right--by the time I got done poking around with a screwdriver,the entire top of the rocker proved to be little more than bondo applied by some previous owner,and where the weatherstripping "lip" was,had completely separated from the floor along the seat and up to the kick panel...............................................................................................................................................................................................................I also found rust on the angle iron looking support where the rubber bushing for the cab mount sits,and it was starting to cave in some...the inner rocker panels was still 90% intact however,the external part of the rocker under the door had a few holes that quickly became BIG holes,so I used some galvanized steel and patched it back together with pop rivets and drive screws--the truck isn't worth doing a frame off resto on it--hated to do a "hack" job,but when your broke and feel welding any patches on is a waste of rods,wire or oxogen,the rivets work just as well,and it'll last as long as I own it,or till it gets scrapped...................................................................Took it for a ride the other day,no more "knocking" from my door now when I go over bumps like before..door closes better now too!...
sorry, could not resist. Joke from another thread.
