[ QUOTE ]
[ QUOTE ]
For those times I can't run a 102" becouse of trees or whatnot, I really like a magnet mount K40. Slap in down on the hood, hook up the coax, and I'm good to go. /forums/images/graemlins/deal.gif
K40 info
[/ QUOTE ]
Ya know, you don't really need to run a 102" whip, most if not all C.B. antennas are actually 102" they are just coiled up to some degree to shorten the overall height.
To the other person, if you are having problems hearing people, the SWR may be off on your setup, your magnet mount should be sufficient for use on the trails. How old is the radio and has it ever ben peaked and tuned? If not have a cb shop clean it up, run some decent coax and also wouldn't hurt to run a nicer antenna, if you still want to run a magnet mount,there are better quality ones out there.
The antenna i run, i bought when i used to drive trucks OTR, it is a 102" antenna, but is coiled up at the bottom, you may be able to see it in my photos of the truck, it's mounted on the drivers side rear bumber, unfortunately, it is very directional where it is mounted, but really don't use it for long distance communications, mainly just around the trails and it works great for that. /forums/images/graemlins/thumb.gif
A buddy of mine has his mounted on the top of the truck, just about in the middle of the roof, he gets better range from his than mine, but then his is using the whole roof as a ground plane, if i wanted to go for the distance thing, i would have done the same thing, but i wanted mine low, out of the way, and just capable to chat with other drivers on the trails or close to me when driving down the road.
[/ QUOTE ] I hear where your comming from, but I have tried the shorter antennas and the 102" Stainless Steel whips out preform everything I've tried.
