Stomis
Professional Amateur
So I got a cclip eliminator kit for my steet trucks 10 bolt. Long story short I got stuck with a "race only" ball bearing version. Im trying to see if I cant manage to find a tapered bearing to replace the ball bearing for DD duty. Im not worried about leaks, just worried about wiping the bearings fast from side to side movement. Ive got internal axle tube seals to handle keeping the oil in the pumpkin.
So I start looking at bearing specs. The Strange ball bearing is 1.562 ID and 3.150 OD. So I start my search off just looking at off the shelf 9in bearings and what do you know, Set 20 big end ford bearings are the same ****ing size... Im saying to myself, you've got to be kidding me with this. Could it really be that simply after going back and forth with strange about how they dont make a taper bearing cclip kit for the truck rears?
I swear between redrilling 5x5 OBS rotors for 5x4.75 and possibly being able to adapt an "add on kit" to make a street cclip kit for big flange 10 bolts Im gonna have to open up an e-store...
