Smokey burnouts
Registered Member
72 blazer: As stated above the PO either cut/broke off or welded up and painted over the center 2 hardtop bolts in the window frame.
My question is, can/should I run the hard top with only the corner visor bolts holding the front?
Rather not open the can of worms it might be fixing the center bolts if not 100% necessary
