Got an aftermarket Grant wheel on my '83 K5. It was straight going down the road but my turn signal cam wasn't right. Read that the horn thingy is supposed to be at 10 oclock, so I undid the wheel screws and clocked it to the wheel. That fixed that but now the wheel was off when going straight. As I remember, the plate the horn thingy goes through goes on the shaft splines only on one way, So, I adjusted the drag link (if that's what you call it) from the box to the steering arm until the wheel is centered. But now the ends only enter the center sleeve to just past the clamps, so I have about an 1-1/2" of engagement. Going the other way they bottom out before the wheel is centered.
Am I good? Is there another way to center things?
