Hi All,
Yesterday I tried installing the power plate TBI spacer from CFM-Tech, as well as a couple of their other parts like the injector spacer, afpr, salad bowl, and fuel line adapter.
I ran into a problem in regards to the fuel lines connecting to the TBI. If I used the stock fittings the fuel lines wouldn't reach because of the new ~3 inch spacer. If I used the adapter (the part that the fuel pressure gauge fits into) then I had about .5-1 inches too much room (the adapter is pretty long).
I was a little worried about bending the fuel lines... wasn't sure if that was ok. Also the distributor coil is kind of in the way, and not that easy to remove because of some plastic in the way of its bolt.
Anyway, I used the search function and found the following comments below. Just wondering if anyone had the same problem and what the did. Or any other suggestions of course, and if it's kosher to bend the fuel lines.
Thanks a lot!
"The only difficulty is that I had to bend and move the fuel lines to accommodate the spacer, which caused a rattle and the fuel lines to contact the body of the truck at first, not a big deal, but it took me a bit to figure out."
"I had to re-mount the dist. coil because the in line fuel pressure guage was in the way. It was also very hard to get the guage to be in the right place. As it is now, its upside down but thats the only way it will go so I guess its fine."
Thanks a lot!
