shouldaboughtahat
Registered Member
You can see from my post count I'm new, but I have been reading and searching this site for years.
I have run into a problem with my 88 k5. Today I changed out the master/slave cylinders for the clutch. I had to remove the duct work under the steering column to unpin the master cylinder. After bleeding everything, but before buttoning everything up I went to start the engine to try engaging the transmission in case I had to bleed things some more. The starter won't even kick in.
So, my question is if anybody can give me some clues of what I might have unplugged or bumped or otherwise screwed up to give me a place to troubleshoot this.
As far as I can tell the switch on the clutch pedal is still okay.
The vehicle is an 88 K5, SM 465 with a Ranger Overdrive and rebuilt drive shafts. Other than that everything else is stock. I've been going since 5:45 this morning, so I am going to get some sleep so I can start same time tomorrow morning. I'll try to check back tomorrow after work.
Thanks in advance for any input. I have picked up so much from this site.
