thedrip
This is a rough sketch of what I came up with tonight for battery mounting on my truck. There will be one battery on each side of the truck. Big plate mounted on the cab back wall, box welded onto the bottom, with nessecary bracing to hold weight. Battery in a plastic marine box, mounted to the plate/bracket. Would end up being ~3-4" below the bottom of the flatbed that will be there eventually, and the bottom would be about even with the top of the frame at that point.
Anyone see any potential issues for mounting the batteries in this fashion? I think the cab wall should be up to it, since Ryoken (I believe, sorry if I mis-remember) has a box holding 2 batteries hanging off his firewall in a similar fashion.
