By Design Poly restricts movement better than rubber which causes the bushing to move in its housing..... a bushing is not supposed to move in its housing. The problem is not the bushing binding.... the real problem is why does it bind.
If the bushing moves in a truck, why wouldn't it in a car application? Almost no suspension bushing I can think of sees up/down or side to side only motion. Every suspension bushing I can think of sees a lateral load as well as the "intended" range of movement.
Examples? 2wd front control arm bushings. Driving straight, pretty much straight up and down travel as you hit bumps. Turn the wheel though, and they are dealing with up and down, AND the lateral load of the turning tire. Rear leaf or coil spring suspensions are the same way, one side up, one side down, the bushings are seeing a lateral load, and if poly binds, (instead of giving like rubber) you are limiting travel by increasing the amount of force it requires to move the suspension, AND making the movement less predictable.
I think if poly were actually so good for suspension, you'd see it in OEM applications more, such as the Camaros, Mustangs, and Vettes, but AFAIK, you don't.
Anyway, theres nothing wrong with disagreeing, and just so we are clear, no hard feelings here. I hate seeing these type of things degenerate into a flame war.
